Последний раз редактировалось Адвокат; 06.03.2008 в 18:17. |
INDEPENDENT Gas Tank Co
Контора которая лепит баки и крылья под заказ. Есть очень хорошие работы, могут пригодиться идеи... INDEPENDENT GAS TANK COMPANY Gilbert, Arizona, USA Tel: 480 633 6700 E-mail: [email protected] www.independentgastank.com Последний раз редактировалось Адвокат; 20.03.2008 в 23:23. |
Зеркала от BARRACUDA
Есть достойные штучки у этих Итальяшек... BARRACUDA Florence, ITALY Tel: +39 055 412 746 E-mail: [email protected] www.barracudamoto.it |
Grandeur Cycle's 'Missing Link'
Недостающее звено в борьбе с вибрацией! Штучка ставится на модели FLH и FLT начиная с 2002 года. Говорят полезная! GRANDEUR CYCLE Jonesville, North Carolina, USA Tel: 336 526 2468 Fax: 336 526 4850 E-mail: [email protected] www.grandeurcycle.com |
Трубы от Vance and Hines
Компания выпустила серию для Harley-Davidson Softails ('86-'06 and '07-'08) и '06-'08 Dyna models VANCE & HINES Santa Fe Springs, California, USA Tel: 562 921 5388 Fax: 562 802 7466 E-mail: [email protected] www.vanceandhines.com |
Новая передача для ХД
Baker release reverse gear BAKER Drivetrain has created the F6R reverse kit for 2007-2008 factory Cruise Drive six-speeds to meet the demands of an aging demographic of Harley riders. The F6R provides a reverse gear which is especially useful for riders of large touring bikes, side cars, trailer users and trikes who find it difficult to push a bike backwards. Lehman Trikes adopted the technology for its Harley-Davidson three-wheel motorcycles and now, the F6R is exclusively distributed via Lehman Trikes and Baker Drivetrain. Reverse is selected by moving the foot shift lever. Down shift into 1st gear, engage the electric safety switch near the handle bars and down shift again to select reverse. Up shift into 1st after completing the reverse maneuver to continue down the road. Internally, the shift drum indexes to select reverse. The drum inherently functions as an interlock and makes it impossible to select reverse and another gear simultaneously. The F6R is over-designed to make it durable under all conditions. Reverse gears and dogs are fully case hardened to HRC58-62 making the F6R as durable in reverse as it is in forward gears. Reverse gear ratio is 4.98:1. This compares to the 1st gear ratio of 3.34 making it 45 percent shorter than 1st gear. The system is compatible with the Baker F6F which reduces 5th gear noise, and is available with cable type or hydraulic clutch actuator side cover. Baker offers an install service on the F6R on low mile six-speed gearsets sent to it for a nominal charge. BAKER DRIVETRAIN Haslett, Michigan, USA Tel: 517 339 3835 Fax: 517 339 4590 E-mail: [email protected] www.bakerdrivetrain.com |
Кит на установку 240 колеса на H-D FLH 1997-2008 models
Переделка 2000-2007 H-D Softail. Кит на установку 300-го колеса!!!! http://www.zeeldesign.com/contenu.asp?Id=2 |
![]() Может прегодиться, особенно зимой, когда преходит пора глобоко заниматься байком своим ![]() http://beltdrives.com/
http://www.asforks.com/
Кит под спортивную переделку
Harley Davidson XR1200 ![]() http://www.vanceandhines.com/xr1200series/racekit.html
#16
При помощи приложения на iphone от http://gaugeface.com/ вы получаете всю инфу о работе мотоцикла! Даже поворотники показывает! Приобретается комплект адаптера, ставим прогу на айфон, подключаем все и вуаля! У тебя бортовой комп
![]() Подходит ко всем харлеям начиная с 2001 года выпуска, за исключением софтейлов 11-го года ( у них иной разъем для подключения кабеля). http://www.youtube.com/watch?v=A9suX...layer_embedded спасибо: http://news.motorbiker.org/blogs.nsf...ing-iphone.htm |
#17
тюнинг для HD Sportster 883-1200
HANDLEBAR AND INSTRUMENT HOLDER KIT TRIPLE TREE KIT INDICATOR LIGHT ADAPTERS HEADLIGHT PROTECTION CONTROL KIT AIR FILTER KIT FRONT PULLEY COVER FRONT PULLEY GUARD GAS CAP BELT COVER WIRING COVER http://www.rizoma.com/ спасибо: http://bikerscafeblog.com/2011/02/19...top-to-bottom/ |
#18
прибовляет мощи от 50 до 65% ![]() http://www.procharger.com/motorcycle_offering.shtml
#19
![]() http://www.dbcustomleather.com/
#20
| Закладки |
| Метки |
| harley davidson, переделка, тюнинг |
| Опции темы | |
| Опции просмотра | |
