#41
Harley recalls 7,000 Softails
http://motorcycleviews.com/recalls/rec11v037000.htm
http://www.recallnewsletter.com/h-d-11v037000 Harley-Davidson Inc. has recalled several thousand Softail motorcycles made in York County for a possible improper seal on a part that can cause the engine to stall, creating a safety hazard. The Milwaukee-based company manufactured the motorcycles between June 7, 2010, and Oct. 8, 2010, according to a report filed with the National Highway Transportation Safety Administration. The report says 6,964 motorcycles were potentially affected by the problem. Harley is contacting owners of the recalled motorcycles, and dealers will fix them free of charge, according to the report. Shares of Harley are traded on the New York Stock Exchange under the stock ticker HOG. источник |
#42
#43
Поправил
#44
Быть точным
приемник (ответ-привет) имубилайзера....
Типа у 7000 тысяч байков этот глюк..... |
#45
Suzuki Recall
SUZUKI / AN400 2008-2009
SUZUKI / DL1000 2008-2009 SUZUKI / GSF1250 2008-2009 SUZUKI / GSX-R600 2008-2009 SUZUKI / GSX-R750 2008-2009 SUZUKI / GSX1300B 2008 SUZUKI / GSX1300R 2008-2010 SUZUKI / GSX650F 2008-2009 SUZUKI / SFV650 2009-2010 SUZUKI / VL800 2008-2010 SUZUKI / VLR1800 2008-2009 SUZUKI / VZ1500 2009-2010 SUZUKI IS RECALLING CERTAIN MODEL YEAR 2008 THROUGH 2010 MOTORCYCLES MANUFACTURED FROM JULY 2007 THROUGH SEPTEMBER 2009, EQUIPPED WITH REGULATOR/RECTIFIER ASSEMBLIES, SUZUKI PART NUMBERS 32800-41F11, 32800-15H10, 32800-05H11, 32800-41G10, 32800-15H00, 32800-18H00, 32800-05G10, 32800-10G10, 32800-05H20, OR 32800-06G01. SOME REGULATOR/RECTIFIER ASSEMBLIES WERE PRODUCED WITH INSUFFICIENT ADHESION BETWEEN THE POWER MODULE (CIRCUIT BOARD) AND THE RECTIFIER CASE THAT CONTAINS A HEAT SINK TO DISSIPATE HEAT. DUE TO INSUFFICIENT ADHESION, HEAT GENERATED ON THE POWER MODULE CIRCUIT BOARD CAN CAUSE THE CIRCUIT BOARD TO DEFORM, AND LIFT OF THE CASE. http://www-odi.nhtsa.dot.gov/recalls...e&refurl=email |
#46
Отзыв Triumph/ ThunderBird
Vehicle Make/ Model : Triumph/ ThunderBird Model Year(s): 2010
Manufacture: Triumph Motorcycles America LTD Mfr’s Report Date: May 09, 2011 NHTSA Campaign ID Number: 11V277000 NHTSA Action Number: N/A Component: Equipment Potential Number of Units Affected: 1,955 Summary: Triumph is recalling certain model year 2010 ThunderBird and ThunderBird ABS motorcycle manufactured from Sept. 2009 through August 2010. These motorcycles were built with an incompatible thread locker/screw combination at the front fender mounting. Consequence: The screws may work loose and the screww heads can contact the side of the front tire, leading to tire deflation, increasing the risk of a crash. Remedy: Dealers will install new screws, free of charge. The manufactuer has not yet provided an owner notification schedule. Owners may contact Triumph Customer Service Department at 1-678-539-8782 Notes: Owners may also contact the National Highway Traffic Safety Administration’s Vehicle Safety Hotline at 1-888-327-4263 (TTY 1-800-424-9153), or go to HTTP://WWW.SAFERCAR.GOV |
#47
Отзыв Виктори 2011 года!
POLARIS IS RECALLING CERTAIN MODEL YEAR 2011 VICTORY CROSS COUNTRY MOTORCYCLES MANUFACTURED FROM JANUARY 1, THROUGH APRIL 11, 2011. THE HANDLEBAR CLAMPS AND/OR RISERS MAY HAVE BEEN MACHINED INCORRECTLY WHICH COULD CAUSE THE HANDLEBARS TO SLIP IN THE CLAMPS.
via www-odi.nhtsa.dot.gov |
#48
Отзыв КТМ 10-11 модельного года
KTM IS RECALLING CERTAIN MODEL YEAR 2010 AND 2011 MOTORCYCLES MANUFACTURED FROM NOVEMBER 2009 THROUGH NOVEMBER 23, 2010. DUE TO IMPROPER HEAT TREATMENT, THE HANDLEBAR CLAMPS CAN DEVELOP CRACKS, ALLOWING THE HANDLEBAR TO MOVE FROM ITS SET POSITION.
#49
Ducati Recalls 2011 Diavel License Plate Holder
Дукати отзывает свою новинку Duval выпущенную с 23 сентября 2010 по 12 мая 2011
общее кол-во отозванных американцев: 964 причина: крепление номерного знака! Vehicle Make / Model: Ducati / Duval Model Year(s): 2011 Manufacture: Ducati North America Mfr’s Report Date: June 16, 2011 NHTSA Campaign ID Number: 11V336000 NHTSA Action Number: N/A Component: Equipment Potential Number of Units Affected: 964 Summary: Ducati is recalling certain model year 2011 Diavel Motorcycles manufactured from Sept. 23, 2010, through May 12 2011. The brass inserts installed in the chain guard may deform over time, resulting in the possible loosening of the license plate holder retaining screws on the rear swing-arm. This situation could cause the license plate holder to become loose during normal operation of the motorcycle. Consequence: Loosening of the license plate holder could interfere with the motorcycle’s rear wheel rotation and thereby increase the risk of a crash. Remedy: Ducati dealers will replace the chain guard with an updated version, manufactured with steel inserts. The service will be performed free of charge. The safety recall is expected to begin during July 2011. Owners may contact Ducati at 1-800-231-6696. Notes: Ducati safety recall number is RCL-11-002. Owners may also contact the National Highway Traffic Safety Administration’ http://usridernews.com/2011/07/07/du...-plate-holder/ |
#50
Polaris Recalls Indian Kickstand 09-2011
Vehicle Make / Model: Indian / Indian
Model Year(s): 2009-2011 Manufacture: Indian Motorcycle Company Mfr’s Report Date: June 24, 2011 NHTSA Campaign ID Number: 11v344000 NHTSA Action Number: N/A Component: Structure:Motorcycle Kickstand/Center Stand Potential Number of Units Affected:699 Summary: Polaris is recalling certain model year 2009-2011 Indian Motorcycles for failing to confirm to the requirements of Federal Motor Vehicle Safety Standard No. 123 “Motorcycle controls and displays.” The side stand may not fold rearward an upward if it contacts the ground when the motorcycle is moving forward. Consequence: If the stand does not fold rearward and upward while the motorcycle moves forward, the driver’s ability to control the motorcyсle could be affected, increasing the risk of a crash. Remedy: Dealers will replace the side stand free of charge. The safety recall is expected to being during August 2011. Owners may contact Indian at 651-408-7579 Notes: Owners may also contact the National Highway Safety Administration’s Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to HTTP://WWW.SAFERCAR.GOV |
#51
Polaris Recalls Indian Headlight Switch 09-2011
Model Year(s): 2009-2011 Manufacture: Indian Motorcycle Company Mfr’s Report Date: June 24, 2011 NHTSA Campaign Number: 11V343000 NHTSA Action Number: N/A Component: Exerior Lighting:Headlights:Switch Potential Number of Units Affected: 699 Summary: Polaris is recalling certain model year 2009-2011 Indian Motorcycles for the body control module (BCM) which can cause the headlight to turn off in some circumstances. If the headlight switch is slowly moved from one position to another (high beam to low beam or low to high beam), both beams may be on momentarily and the BCM interprets this as an overload condition.. Consequence: The BCM turns off the headlight until the next time that the key is turned on. The unexpected loss of headlight function could impair a driver’s visability, increasing the risk of a crash. Remedy: Dealers will replace the BCM free of charge. The safety recall is expected to begin during August 201. Owners may contact Polaris at 1-651-408-7579 Notes: Owners may also contact the National Safety Highway Safety Administration’s Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to HTTP://WWW.SAFERCAR.GOV |
#52
Yamaha Recalls 2011 FJR1300 Brake Switch
Vehicle Make / Model: Yamaha / FJR1300
Model Year(s): 2011 Manufacture: Yamaha Motor Corp., USA Mfr’s Report Date: June 24, 2011 NHTSA Campaign ID Number: 11V340000 NHTSA Action Nmber: N/A Component: Exterior Lighting: Brake Lights:Switch Potential Number of Units Affected:260 Summary: Yamaha is recalling certain model year 201 FJR1300 motorcycles manufacuted from Jan. 2011 through April 2011. The brake light may not illuminate when the front brake lever is applied because the activating mechanism in the front brake switch can bind. Consequence: When the motorcycle operator applies only the brake, the brake light may not come on to alert other drivers, increasing the risk of a crash. Remedy: Yamaha dealers will install a new front brake switch free of charge. The safety recall is expected to begin during July 2011. Owners may contact Yamaha at 1-800-962-7926 Notes: Owners may also contact the National Highway Traffic Safety Administration’s Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9152), or go to HTTP://WWW.SAFERCAR.GOV |
#53
Polaris Recalls Kingpin & Jackpot Backrest
Vehicle Make/ Model: Victory / Jackpot
Victory / Kingpin Model Year(s): 2006-2011 2004-2011 http://usridernews.com/2011/07/12/po...kpot-backrest/ |
#54
Honda Recalls Rear Brake Reservoir For ST1300
Vehicle Make / Model: Honda / ST1300
Honda / ST1300A Honda / ST1300PA Model Year(s): 2008-2010 2008-2010 2009 Manufacture: Honda (American Honda Motor Co.) Mfr’s Report Date: July 11, 2011 NHTSA Campaign ID Number:11V356000 NHTSA Action Number:N/A Component: Service Brakes, Hydraulic: Foundation Component:Hoses,Lines/Piping, and Fittings Potential Number of Units Affected: 2,232 Summary: Honda is recalling certain model year 2008 through 2010 ST1300 motorcycles manufactured from Nov. 15, 2007, through may 27, 2010, model year 2008 through 2010 ST1300A motorcycles manufactured from Nov.7, 2007, through April 6, 2010, and model year 2009 ST1300A Police motorcycles, manufactured from Nov. 18, 2008, through Dec. 8, 2009. When the rear suspension of the motorcycle is repeatedly bottomed out (fully compressed) the rear brake reservoir hose mat become damaged and leak fluid. Consequence: The rider will experience a loss of rear brake performance or function which increases the risk of a crash. Remedy: Dealer will replace the rear brake reservior hose free of charge. The safety recall is expected to begin on or before July 26, 2011. Owners may contact Honda at 1-800-999-1009 Notes: Honda safety recall NO. R86. Owners may also contact the National Highway Traffic Safety Administration’s Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to HTTP://WWW.SAFERCAR.GOV |
#55
2011 Ducati Recall
2011 Ducati Recall
Ducati is recalling 2011 Diavel motorcycles due to kickstand/center stand issues, the Italian manufacturer reported Wednesday. Ducati says 919 motorcycles are affected. Certain model Diavel motorcycles manufactured from May 18, 2010, through June 13, 2011 were built with insufficient material in the pivot area of the side stand; this could result in possible bending and breakage of the side stand, causing the motorcycle to fall over. Ducati will notify owners, and authorized dealers will replaced the side stand and pivot bolt free of charge. The safety recall is expected to begin this month (August). Owners may contact Ducati at 1-800-231-6696, or visit ducati.com. Owners may also contact the National Highway Traffic Safety Administration's Vehicle Safety Hotline 1-888-327-4236 (TTY 1-800-424-9153), or visit safercar.gov. NHTSA Campaign ID Number: 11V413000 http://www.ultimatemotorcycling.com/...el-motorcycles |
#56
Recall: Kawasaki ZX1000KBF and ZX1000JBF
Date created: 5th September 2011
Product information Product description Models: ZX1000KBF - 2011 NINJA ZX10-R ABS ZX1000JBF - 2011 NINJA ZX10R Identifying features Campaign number: DAD601A Target number: 280 VIN range ZX1000KBF - JKAZXCJ1#8BA000069 to JKAZXCJ1#6BA006422 ZX1000JBF - JKAZXCJ1#1BA000008 to JKAZXCJ1#4BA000925 What are the hazards? Loss of ignition could cause the engine to stop running, creating the potenial for an accident. What are the defects? The main wiring harness may rub against the rear of the frame, causing an electrical fault. Where the product was sold Nationally Supplier Kawasaki Motors Pty Ltd What should consumers do? Kawasaki will write to owners of affected vehicles. Owners are advised to return the affected vehicles to their authorised Kawasaki dealer who will perform the necessary repairs free of charge. http://www.bikesonshow.com/content/r...-and-zx1000jbf |
#57
Recall: Ducati DIAVEL Motorcycles
Product information Product description Ducati DIAVEL motorcycles, MY 2011 Identifying features Campaign number: 835/11 Target number: 156 See attatched VIN list. What are the hazards? The motorcycle may fall and potentially cause injury. What are the defects? The side stand may bend or break under heavy load while the bike is resting on it. Where the product was sold Nationally Supplier Ducati Motor Holding What should consumers do? Ducati will write to owners of affected motorcycles. Owners are advised to contact their authorised Ducati dealer to arrange for the rectification to be carried out, free of charge. Advertisements and supporting documentation http://www.bikesonshow.com/content/r...el-motorcycles Список отзываемых VIN: http://www.recalls.gov.au/content/it...VIN%20List.pdf |
#58
Recall for 2009-2011 Yamaha V-Max
Yamaha is issuing a recall campaign on certain 2009-2011 V-Max power cruisers due to a potential risk of oil pump malfunction. According to documents released by the National Highway Traffic Safety Administration, abnormally high oil pressure can build up within the oil pump of certain Yamaha V-Max models. The high pressure may force the washer on the oil pump shaft against the oil pump housing, causing oil to stop pumping through the engine. Yamaha dealers will replace the oil pump with a new unit at no charge. The work can be completed without having to drain the engine oil. The recall campaign affects 2,300 units, all produced between Sept. 2008 and April 2011. [Source: NHTSA campaign ID 11V483000] http://blog.motorcycle.com/2011/09/3...-yamaha-v-max/ |
#59
Yamaha Recalls V Star, Super Tenere
Yamaha отзывает с рынка следующие модели: V Star 950, V Star 950 Touerer, V Star 1300, V Star 1300 Tourer и Super Tenere.
Yamaha отзывает 2,800 мотоциклов V Star: 2009-2012 модельного года XVS95/CT (V Star 950/V Star 950 Tourer) выпущенных с октября 2008 по август 2011, и модельный год 2007 XVS1300/CT (V Star 1300, V Star Tourer) выпущенные с августа 2006 по март 2007. Проблемы с соединением топливного шланга, бензин со временем может протекать, а сие опасно "There may not be a proper seal between the fuel pipes for the fuel injectors and the fuel hose that connects them due to an improperly molded fuel hose. Over time, pressurized fuel may began leaking, causing a fire hazard, yamaha says." Yamaha says 1,069 Super Tenere motorcycles are affected - 2012 XTZ12B/BC manufactured from June 1, 2011, through Aug. 31, 2011. During the assembly process, the fuel-pump o-ring may have been installed incorrectly in its grove. If the tabs located around the inner circumference of the o-ring were not seated into the groove properly, things could be damaged. This may cause a fuel leak, causing a fire hazard. Yamaha will notify owners, and dealers will replace the defective parts free of charge. The safety recalls are expected to began Nov. 11. Owners may contact Yamaha at 1-800-962-7926. Notes: Owners may also contact the National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or visit safercar.org |
#60
RECALL: KAWASAKI ZX-6R & ZX-10R
Отзыв зеленых ракет
Kawasaki is recalling certain ZX-6R & ZX-10R motorcycles for a regulator/rectifier that may be improperly charging the motorcycle’s battery. Concerning Kawasaki Ninja ZX-6R motorcycles from 2009-2012 andKawasaki Ninja ZX-10R motorcycles from 2008-2011, the NHTSA is reporting that20,544 motorcycles are affect by the recall, all of which were manufactured between December 14, 2007 and July 26, 2011. The recall is expected to start February 27, 2012 with Kawasaki notifying affected owners. Dealers will repair affected ZX-10R & ZX-6R free of charge. Concerned Kawasaki ZX-10R owners can contact Kawasaki’s consumer services department at1-949-770-0400.As always the NHTSA is available at1-888-327-4236 andwww.safercar.gov. Source:NHTSA http://www.asphaltandrubber.com/reca...arging-recall/ |
Метки |
recalls, брак, мотоцикл, отзыв |
