#21
Свежие отзывы. Привожу без именений...
DUCATI Recall (#2008380)
Models Involved: 2008 Desmosedici RR Number of Vehicles: 21 Problem: On certain motorcycles, the position of the hose clamps on the fuel filler drain hose & fuel breather hose is incorrect and the two hoses may get damaged. This situation has potential for a fuel leak and a fire which could result in a loss of vehicle control causing an accident with personal injuries or death. Correction: Dealers will replace the fuel filler drain & fuel breather hoses and reposition the hose clamps. __________________________________________________ ______________________________ BIG BEAR CHOPPERS Recall (#2008381) Models Involved: 2004-2006 Devils' Advocate, Sled, Venom Number of Vehicles: 12 Problem: On certain motorcycles, the frame welds may not have sufficient strength where the neck is connected to the backbone and the down tube. There might be some instances where customers may have modified their frame by adding holes, grounded down welds, and not properly torqued the top motor mount. The weld could fail resulting in a separation of the neck from the frame which could result in a loss of vehicle control and causing an accident with personal injuries or death. Correction: Dealers will inspect and repair affected vehicles __________________________________________________ ______________________________ CMI MOTOR Recall (#2008382) Models Involved: 2008 Striker Number of Vehicles: 200 Problem: On certain vehicles, the rear wheel hub may develop a stress related crack which could cause the rear wheel break and fall off. This situation could result in a crash causing personal injury to the rider and property damages. Correction: Dealers will replace with improved parts. __________________________________________________ ______________________________ KAWASAKI Recall (#2008383) Models Involved: 2008 KL650E8F Number of Vehicles: 1,688 Problem: On certain motorcycles, the turn signal mounting stalk(s) can break causing failure of the turn signal to clearly indicate the rider's turn intentions. This situation could lead to a crash causing personal injury or death. Correction: Dealers will replace all four turn signal assemblies. __________________________________________________ ______________________________ BUELL Recall (#2008389) Models Involved: 2009 1125CR Number of Vehicles: 28 Problem: On certain motorcycles, the rear cylinder cam chain tension guide may experience premature failure. This can cause plastic debris which can block the oil pump screen, leading to possible oil starvation and engine seizure. An engine seizure may cause the rear wheel to lock-up which could lead to a crash causing personal injuries or death. Correction: Dealers will replace the rear cam chain tensioner with an updated tensioner. __________________________________________________ ______________________________ BUELL Recall (#2008390) Models Involved: 2009 XB12XP, 2008-2009 XB12XT Number of Vehicles: 82 Problem: On certain motorcycles, the windscreen is mounted with a rubber-mounted nut which may become dislodged and hit/distract the rider while riding. This situation could result in a crash causing personal injuries or death. Correction: Dealers will replace the two rubber-mounted nuts with new fastener assemblies. http://cmgonline.com/content/view/1041/46/ |
#22
Suzuki GSX1300R K8 Hayabusa recall
Модель 2008 года уже отозвана на ремонт. Проблемы с проводкой. http://www.motorcycle.in.th/article....ayabusa_recall |
#23
Канадский отзыв Хонды и БМВ
Latest Recalls
Written by CMG Staff on Wednesday, December 3rd, 2008 HONDA Recall (#2008303) Models Involved: 2007-2008 CRF150R, 2007-2008 CRF150RB Number of Vehicles: 1,077 Problem: On certain motorcycles, the swing arms may experience cracking of welds which can result in separation of the cast cross-member and extruded right side of the swing arm. If it occurs, it could affect the rider's ability to control the motorcycle which could result in a crash causing personal injuries or death. Correction: The dealers will replace the swing arm free of charge. __________________________________________________ ______________________________ BMW Recall (#2008395) Models Involved: 2006-2007 HP2 Enduro Number of Vehicles: 44 Problem: On certain motorcycles, due to build tolerances and the length of front threaded fastener used on the Paralever link, there is a possibility that the fastener may come loose due to insufficient torque and over time separate from its housing. This situation could compromise the handling of the motorcycle which could result in a crash causing property damages, personal injuries or death. Correction: Dealers will replace the existing fastener with an improved one.
С Уважением, Адвокат! |
#24
2009 Harley Davidson Отзыв с рынка: FXDB, FXDC, FXDF, и FXDL модели
С рынка отозвано 349 мотоциклов. Проблемы с топливной системой (сварили криво бак). При наклоне мотоцикла возможна утечка топлива, типа можно запалить шкирку... http://nwhog.wordpress.com/2008/12/0...a-super-glide/ http://www.usrecallnews.com/2008/12/nhtsa-2656.html |
#25
Отозваны V-твины от Хонды!
Хонда VT600s, VLXs 2006-2007 годов выпуска
Ходна VT750 и VTX1300 2007-2008 годов Заводской брак присутствует у больше чем 39000 мотоциклов!!! Требуется замена топливного клапана, возможны протечки и возгарания! http://www.motorcyclecruiser.com/new...all/index.html |
#26
Yamaha FJR1300 Recall
Отзываются Ямахи FJR1300 начиная с 2006 г.в. по 2009.
Выявлены проблемы с зажиганием! Ремонт у диллеров с 16 января. Если тащили своего коня со штатов, то это для Вас! Manufacturer: Yamaha Motor Corporation, USA Model Year: 2006-2009 Models affected: FJR1300 NHTSA Campaign Number: 09V002000 Potential Units Affected: 9300 Problem: Yamaha is recalling 9,300 model year 2006-2009 FJR1300 motorcycles. The internal switch wiring could become disconnected. If this occurs electrical current flow will be stopped and the engine could stall. If the engine stalls, the operator may be unable to start or restart the engine increasing the risk of a crash. Corrective Action: Dealers will replace the ignition switch free of charge. The recall is expected to begin on or before January 16, 2009. Owners may contact Yamaha at 1-800-962-7926. http://thekneeslider.com/archives/20...jr1300-recall/ |
#27
Как проверить свою Хонду на участие в отзывных компаниях?
На сайте российской Хонды теперь можно проверить, попал ты или нет...
http://www.honda.co.ru/service/checkmoto.shtml |
#28
Очередное сообщение об отзыве
#29
2008 BMW F800 GS Recall
Не долго мучалась баварская новинка, спеклась и она... Отзывают в Северной Америке. Manufacturer: BMW of North America Model Year: 2008 Models affected: F800 GS NHTSA Campaign Number: 09V088000 Problem: BMW is recalling model year 2008 F800 GS motorcycles. The axle shaft wall thickness may not have been manufactured according to specifications. If the wall thickness was not sufficient, the axle shaft could deform and could break increasing the risk of a crash. Corrective Action: Dealers will inspect the axle shaft assembly and replace or repair the necessary components free of charge. The manufacturer has not yet provided an owner notification schedule. Owners may contact BMW at 1-800-831-1117. Источник: http://thekneeslider.com/archives/20...800-gs-recall/
#30
Buell Recalls Over 3,000 XB12R’s
проблемы с передними тормозами! Диллеры ждут... Документы про отзыв http://www-odi.nhtsa.dot.gov/recalls...e&refurl=email Buell Recalls 2010 XB12Xs and XB12XTs
#31
BMW K1300 GT - K1300 S - Brake Fluid Foaming Recall
BMW has issued a recall for 2009 BMW K1300 GT and K1300 S motorcycles for a problem with brake fluid foaming. Please read the details below.
Manufacturer: BMW of North America Model Year: 2009 Models affected: K1300 GT, K1300 S NHTSA Campaign Number: 09V202000 Problem: BMW is recalling certain model year 2009 K1300 S and K1300 GT motorcycles manufactured between October 1, 2008 and May 1, 2009. In certain riding conditions involving increased vibration, the brake fluid in the front reservoir can foam. This could lead to a reduced braking capability of the front brake system, possibly resulting in a crash. Corrective Action: The manufacturer has not yet provided the agency with a remedy or notification schedule. Owners may contact BMW at 1-800-831-1117. http://thekneeslider.com/archives/20...oaming-recall/ |
#32
Harley Davidson FLSTSB FXSTSSE2 FXSTSSE3 Brake Recall
Harley Davidson has issued a recall for over 11 thousand FLSTSB FXSTSSE2 and FXSTSSE3 models for a problem with the brakes. Please read below for further details.
Manufacturer: Harley Davidson Models affected: 2008-2009 FLSTSB 2008 FXSTSSE2 2009 FXSTSSE3 NHTSA Campaign Number: 09V211000 Potential Units Affected: 11005 Problem: Harley Davidson is recalling 11,005 FLSTSB, FXSTSSE2, and FXSTSSE3 model year 2008 and 2009 motorcycles. The acorn stud at the brake reaction link may fall out during use. If this occurs, the front brake and fender assembly would no longer be adequately retained. This condition could lead to a crash and potential injury to or death of the rider. Corrective Action: Dealers will replace the existing acorn stud with a new acorn stud and retaining clip. The recall is expected to begin during June 2009. Owners may contact Harley Davidson at 1-414-343-4056. http://prostreetblog.com/2009/06/19/...-brake-recall/ |
#33
Harley Davidson 2009 FLTRSE3 CVO Road Glide ОТОЗВАН!
Причина отзыва: бракованные задние диски источник: http://thekneeslider.com/archives/20...-wheel-recall/ |
#34
2009 Buell XB12SS Front Brake Recall
собсно все просто, отозван моторчег 2009 года...
Manufacturer: Harley Davidson Motorcycle Company Models affected: 2009 XB12SS NHTSA Campaign Number: 09V347000 Potential Units Affected: 405 Problem: Buell is recalling model year 2009 XB12SS motorcycles. The front brake line may contact the front tire. This contact could cause a hole to develop in the front brake line, allowing brake fluid to leak this condition might cause an ineffective front brake and lead to a crash. Corrective Action: Dealers will inspect the front brake line and if undamaged, install a guide on the line. If the line is damaged, it will be replaced and re-routed. Either repair will be performed free of charge. The recall is expected to begin on or before September 21, 2009. Owners may contact Buell distribution company at 1-414-343-8400. http://thekneeslider.com/archives/20...-brake-recall/ |
#35
Отозваны североамериканские BMW R1200GS!!
The BMW R1200GS and the FX-28 helmet from AFX were the subject of recall notices filed in August with the National Highway Traffic Safety Administration.
BMW of North America issued a recall on 2006-2008 R1200GS motorcycles. The fuel pump control unit housings of the affected bikes may not have proper sealing. As a result, water can enter the control unit housing, creating a humid atmosphere which may corrode the fuel pump. The recall affects R1200GS produced between August 2006 and January 2008. BMW has not announced a remedy for the issue yet. It is also unclear whether the R1200GS Adventure is affected. Owners are asked to contact BMW at 1-800-831-1117 for more information. Helmet manufacturer AFX North America issued a recall on its FX-28 helmet. The recall notice applies to helmets produced in December 2007, sized extra small, small and medium. The affected helmets fail to comply with the penetration test requirements of Federal Motor Vehicle Safety Standard 218. An estimated 984 helmets may be affected by the issue. AFX will replace recalled helmets with helmets that do comply with the required safety tests. AFX FX-28 owners are asked to look inside their helmets behind the comfort liner cloth for a label which list the date of production. If the FX-28 helmet is labeled “Production date: 2007/12” and is extra small, small or medium, owners are asked to contact AFX at 1-877-686-6477. http://www.motorcycle.com/news/augus...ces-88696.html |
#36
Ducati Recalls 2010 F1098S Streetfighter Motorcycles for Engine Stalling
Собсно все тут:
http://motorcycleviews.blogspot.com/...10-f1098s.html |
#37
Triumph Sprint ST 1050 Rear Suspension Recall
Triumph Sprint ST 1050 производство мотоциклов с 4 ноября 2004 года по сентябрь 2009 года Проблемы с коррозией задней подвески. подробности: http://thekneeslider.com/archives/20...ension-recall/ |
#38
Harley-Davidson отзывает Туринги 2009 и 2010 модельного года!
Отзываются Туринги изготовленные начиная с 6 июня 2008 по 19 ноября 2009 года! Отзыву подлежат в том числе модели CVO.
Обнаружена проблемка в креплении топливного бака. Отзыву подлежат 111569 единиц.
подробности: http://www-odi.nhtsa.dot.gov/recalls...e&refurl=email http://motorcycleviews.com/recalls/m...clerecalls.htm |
#39
BMW Recalls 2009-10 K1300 S и GT
http://www-odi.nhtsa.dot.gov/recalls...rue&refurl=rss
BMW recalls some F650 and F800GS bikes http://www.topix.net/motorcycles/201...f800gs-bikes-2 Последний раз редактировалось Адвокат; 10.01.2010 в 19:12. |
#40
Honda recalls VFR1200F
Собсна не долго мучилась старушка, не успела выйти - тут же отзыв
http://www.motorcyclenews.com/MCN/Ne...alls-VFR1200F/ |
Метки |
recalls, брак, мотоцикл, отзыв |
